Numar total de mesaje in forum: 238898
Starlight Xpress SXV-H9C Color CCD Camera deep sky -30C
piskota
Data inscrierii: 01 Ian 2009
MesajTrimis: 02 Mar 2021 13:34 Download mesaj
Titlul subiectului: Starlight Xpress SXV-H9C Color CCD Camera deep sky -30C
Vand camera racita -30C sub ambient.
rezolutie: 1392x1040!
Merge foarte bine, pot trimite darkuri cine este interesat.
CCD type: Sony ICX285AK Exview interline imager with RGBG Bayer color filter matrix.
CCD size: Active area 8.95mm x 6.7mm
CCD pixels: 1392x 1040 pixel array. Each pixel is 6.45 x 6.45uM (or 12.9 x
12.9uM in binned 2x2 mode).
Well depth: Full res. mode 27,000e.
Mean visual QE:
Approx. 25% effective, 60% for pixels at peak response
Useful spectral response: 360nM? 1100nM
Readout noise: Approx. 7e RMS typical, 12e max.
Back focal distance: The CCD is approximately 17.5mm from the barrel front.
Camera size: 63mm diameter x 100mm long
CCD Quality Grade 1 or better - No bad columns, no dead pixels
Spectral Response QE max at 540nM (~65%), 50% roll-off at 400nM and 750nM
Readout noise Less than 12 electrons RMS - typically ONLY 7 electrons!
Anti-blooming Overload margin greater than 800x
Data format 16-bits
System gain 0.45 electrons per ADU
Computer Interface USB 2.0 compatible interface
Image download time Typically 3.5 - 4 seconds at full resolution
Power requirements 115VAC / 240VAC @ 12VA, or 12VDC @ 750mA max
Cooling system Regulated constant current cooling supply with two-stage thermoelectric cooler to give a CCD temperature of approximately -30?C below ambient
Weight Approx. 350g
pret 1500ron.
Vine cu cablu de conectare alimentator, power supply.
pentru detalii lasati mesaj va rog. mersi
 Marime fisier:  100.38 kb
 Vizualizat:  de 1375 ori
 Marime fisier:  360.07 kb
 Marime fisier:  319.18 kb
 Marime fisier:  375.5 kb
Nullius in verba.
eduardlapas
Data inscrierii: 08 Mai 2019
MesajTrimis: 04 Mar 2021 16:09 Download mesaj
V-am trimis PM
piskota
MesajTrimis: 10 Mar 2021 07:51 Download mesaj
Titlul subiectului: buna ziua
Vandut. Se poate inhide. Multumesc
Nullius in verba.
