Numar total de mesaje in forum: 237799 |
Numar de utilizatori inregistrati: 2896 |
Cel mai nou utilizator inregistrat: paulbth |
radur Membru
Data inscrierii: 15 Oct 2015 Mesaje: 202
Trimis: 02 Sep 2018 13:49 Download mesaj |
| Are la farnell, dar am eu 2 deja, si cum nu folosesc niciuna momentan pentru ca am gasit o platforma mica pt focuser https://www.dfrobot.com/product-1075.html iti pot da una din ele daca esti din Bucuresti si iti faci niste timp liber
Data inscrierii: 02 Apr 2010 Mesaje: 5220
Trimis: 02 Sep 2018 14:07 Download mesaj |
Referitor la acel al optulea pas mai puternic, din documentatia driver-ului A4988, poate ajuta la ceva:
Mixed Decay Operation. For some applications where microstepping at very low speeds is necessary, the lack of back EMF in the winding causes the current to increase in the load quickly, resulting in missed steps. This is shown in Figure 2. By pulling the ROSC pin to ground, mixed decay is set to be active 100% of the time, for both rising and falling currents, and prevents missed steps as shown in Figure 3.
Low Current Microstepping. Intended for applications where the minimum on-time prevents the output current from regulating to the programmed current level at low current steps. To prevent this, the device can be set to operate in Mixed decay mode on both rising and falling portions of the current waveform. This feature is implemented by shorting the ROSC pin to ground.
La Big-Easy Driver, acel pin nu este legat direct la masa (ci cu un rezistor de 20k - adica foloseste modul ala cu salturi la turatii mici), dar se poate face relativ usor. Exemplul din documentatie este la 8 micropasi/s, deci cred ca putem considera viteza folosita ca fiind "very low speed".
P.S.
In loc de RTC puteti folosi GPS ... dar oare chiar este nevoie ?
76.56 kb |
de 8345 ori |
Data inscrierii: 02 Aug 2008 Mesaje: 9804
Trimis: 02 Sep 2018 19:06 Download mesaj |
Mulțumesc, radur, da, ne putem întâlni, stau în București acum, pm pentru detalii.
Mulțumesc, nobody, voi testa când va fi timp, momentan sunt alte priorități. Din câte am văzut ceasul RTC sau GPS deja sunt mofturi, quartz-ul de la Arduino e oricum mai stabil decât circuitul cu timer 555 pe care l-am făcut inițial.
Al3cks Membru
Data inscrierii: 13 Aug 2017 Mesaje: 25
Trimis: 01 Oct 2018 23:06 Download mesaj |
Ma bag si eu aiurea, cu citit doar printre randuri pentru ca vreau sa fac ceva similar, dar pentru ceva mai mare.
De ce nu folositi un motor cu reductor pana la urma?
Eu mi-am comandat asa ceva pentru a antrena platforma ecuatoriala. Soseste peste o saptamana si intre timp imi adun si componentele de comanda, cel mai probabil un Arduiono Pro Mini cu un driver cu microstepping.
Acesta este motorul:
https://www.ebay.co.uk/itm/121683241468
Cadru NEMA 11, reductor de 100:1 cu joc <1 grad (exista si reductoare separate mai scumpre cu jocuri <15 arcmin) si axul reductorului de 6mm. Mai sunt si alte variante de la acest seller.
_________________ Pentax SP 10x50 WP
SkyWatcher 300P FlexTube
Watch-House Eq. Platf. + SkyHub DSC
ES 68 28mm, TV Delos 17.3mm
TV 2x, 3x Barlows |
jimao22 Moderator
Data inscrierii: 12 Apr 2010 Mesaje: 2924
Trimis: 09 Mar 2019 23:55 Download mesaj |
Am sa redeschid acest topic fiindca montura asta a ajuns la mine si s-a dezvoltat destul de mult de la varianta in care a sosit. Cateva poze au fost postate pe http://www.astronomy.ro/forum/viewtopic.ph...;start=135 , dar cum am lucrat destul de mult la montura si inca mai este ceva de lucru pana sa ajung la faza pe care sa o consider finala, nu are rost sa incarc acel topic cu evolutia proiectului ci am sa continui aici.
Deocamdata o mica recapitulare cu ce s-a facut de cand a ajuns la mine montura:
- i-am luat o luneta polara - un element esential pentru un astfel de tip de montura
- i-am luat un trepied de Star Adventurer
- am luat o pana ecuatoriala de la aceeasi mini-montura produsa de Sky Watcher
- am luat 2 platforme reglabile "L" de la aceeasi Star Adventurer
- am mai luat o contra-greutate de la aceeasi mini-montura
- i-am instalat un finder
Tavi (aka Erwin) a facut un modul de comanda pe baza de ARDUINO pentru motorul pas-cu-pas, ce permite ajustarea fina a vitezei siderale. In plus a aparut si o viteza lunara si o viteza foarte mare pentru rewind in pozitia de start.
Cam aici ramasesem ultima data...
| Montura cu o singura platforma "L" reglabila |
1021.24 kb |
de 7380 ori |
| Montura cu 2 platforme "L" reglabile si o contragreutate |
1013.79 kb |
de 7380 ori |
| Montura cu finderul montat |
1.46 MB |
de 7380 ori |
| Montura cu finderul montat - vedere frontala |
917.94 kb |
de 7380 ori |
jimao22 Moderator
Trimis: 10 Mar 2019 00:18 Download mesaj |
Un lucru foarte important de facut era sa stabilesc ce valoare au parametrii din programul de control (ARDUINO) astfel incat viteza de tracking sa fie cea siderala.
Prima data a trebuit sa stabilesc care este viteza actuala si sa determin cu precizie unghiurile importante ale sectorului de cerc pe care se face angrenarea. Pentru asta am folosit un raportor special, recuperat dintr-o fosta uzina devenita intre timp morman de fiare vechi.
Am gasit ca pentru o cursa completa de arc avem 50,6 grade iar unghiul dintre bratele arcului este de 35 de grade. Pe acesta din urma am facut experimentarile in cele ce a urmat.
Plecand de la masura unghiului de 35 de grade, este clar ca in mod sideral cele 35 de grade ar trebui sa fie parcurse in 2 ore si 20 de minute (35/360*24 = 2.3333...). Jumatate din acest unghi (deci pana la centru, la axa de simetrie) ar trebui sa fie parcurs in 1 ora si 10 minute. Primele masuratori mi-au dat ca montura face acel parcurs in 43 minute si 47 secunde. Deci parametrul din program trebuie redus cu un factor de aproximativ 0.625. Valoarea exacta am sa o stabilesc prin experimentari in camp, urmarind o stea. Momentan este suficient pentru o ajustare grosiera.
802.86 kb |
de 7372 ori |
1.31 MB |
de 7372 ori |
jimao22 Moderator
Trimis: 10 Mar 2019 00:32 Download mesaj |
Masuratoarea aceasta mi-a aratat insa si ceva nedorit dar previzibil. Motorul se opintea destul de tare ca sa duca greutatea de la partea superioara. Nu stiu in ce masura acest fapt afecteaza precizia trackingului, dar ca sa evit orice surpriza, am hotarat ca trebuie sa fac ceva ca sa contrabalansez greutatea si dupa axa RA, nu numai dupa DEC cum era acum.
Si fiindca nu folosisem pana acum decat o singura sina de la o platforma de reglaj "L", una fiind disponibila si relativ inutila pana acum, am hotarat sa o folosesc impreuna cu o a doua greutate similara cu cea existenta, pe care sa o comand zilele astea. Modul in care m-am gandit sa fac acest lucru a fost sa folosesc gaurile tehnologice existente deja pe montura impreuna cu sina respectiva, legatura intre aceste elemente facand-o cu o piesa aditionala pe care am uzinat-o azi pe freza.
Desi piesa cea noua permitea orice forma posibila, prelucrarea ei a fost mult mai laborioasa decat ma asteptam.
| Piesa de legatura montura-sina cu contragreutate nr. 2 |
914.01 kb |
de 7366 ori |
| A aparut si sina in peisaj... |
810.21 kb |
de 7366 ori |
| Montura si piesa noua sablate, pregatite de vopsire |
1011.24 kb |
de 7366 ori |
jimao22 Moderator
Trimis: 10 Mar 2019 00:53 Download mesaj |
Si asa am ajuns cu piesele acasa si a ramas ultimul lucru de facut (pentru azi) - si anume - vopsirea.
Am ales o culoare neconventionala, plecand de la faptul ca pana ecuatoriala era rosie. Asa ca am hotarat ca si montura pe fata ei frontala si posterioara sa fie tot rosie. Flancurile le-am lasat argintii si asa vor ramane, pentru un pic de contrast. Produsul trebuie sa arate si bine, nu doar sa fie functional.
In fine, o observatie pentru munca si investitia financiara facuta pana acum: am mari sperante si asteptari de la aceasta montura speciala.
Faptul ca transmisia miscarii este facuta prin frictiune, ca si la vestita Mesu Mount 200 - http://www.mesu-optics.nl/mesu200_en.html - [o montura olandeza extrem de performanta, care la o marime si greutate comparabila cu un EQ8 duce o greutate de 100 kg (!!!)] ma face sa cred ca va fi mult superioara monturii Star Adventurer care este din aceeasi clasa cu ea. Este si ce vreau eu, pentru ca Star Adventurer duce un DSLR, iar montura mea va trebui sa duca o luneta (e adevara, nu foarte mare), o camera CCD (ATIK 460 EX) si eventual un reducator de focala (care este greu si voluminos). Asta in conditiile unei portabilitati foarte mari, montura fiind totusi una grab&go.
De aceea sunt cuprins de o mare efervescenta cu lucrul la aceasta montura si sper ca asteptarile sa nu imi fie inselate.
| Montura vopsita, cu greutatea (singura momentan) in partea inferioara |
1.05 MB |
de 7372 ori |
969.71 kb |
de 7372 ori |
| Greutatea pusa inapoi pe axa de declinatie. |
901.24 kb |
de 7372 ori |
1.32 MB |
de 7372 ori |
1.38 MB |
de 7372 ori |
StarChild Membru
Data inscrierii: 29 Mar 2011 Mesaje: 1609
Trimis: 10 Mar 2019 11:25 Download mesaj |
Super tare! Felicitari!
Chiar arata f bine, iti tin pumnii sa si functioneze conform asteptarilor.
jimao22 Moderator
jimao22 Moderator
Trimis: 12 Mar 2019 21:57 Download mesaj |
Astazi mi-a sosit greutatea suplimentara de la Telescop Expert. Montura este (pentru moment, in aceasta faza) completa. Asa arata in momentul de fata, complet echilibrata pe ambele axe. Cand am sa ii pun camera si eventual reducatorul de focala, o sa se dezechilibreze iar, dar oricum ce avem acum e mai mult decat nimic si va face viata motorului mult mai usoara.
Am facut si 2 capacele de protectie pentru luneta polara, care era expusa elementelor si sortii prea mult parca. Capacelele sunt din duraluminiu, vopsite negru.
Mai am de rezolvat o problema inainte de a incepe sa fac calibrarile pentru viteza siderala si lunara si sa incep testele. Tija greutatii de jos se intersecteaza cu axul motorului, care iese prea mult in peisaj. Va trebui fie sa tai/polizez axul (1), fie sa il bat usor si sa iasa pe partea opusa a motorului circa 4 mm (2), fie sa fac o placuta de distantare intre motor si suportul de prindere , tot de 4 mm, ca sa dispara axul din traiectoria barei contragreutatii. Inca nu m-am hotarat ce solutie sa adopt.
| Montura cu cele 2 contragreutati instalate. |
1001.21 kb |
de 7246 ori |
| Capacel obiectiv luneta polara |
661.91 kb |
de 7246 ori |
| Capacel ocular luneta polara |
733.25 kb |
de 7246 ori |
754.45 kb |
de 7246 ori |
Trimis: 12 Mar 2019 22:21 Download mesaj |
Nu poti monta invers sina care tine bara cu contragreutatea ?
Eu n-as umbla la axul motorului (polizat, batut, presat).
_________________ Then it comes to be that the soothing light at the end of your tunnel
Trimis: 12 Mar 2019 23:08 Download mesaj |
Într-adevăr, la presă axul se poate strâmba un pic. Pentru că angrenarea este prin fricțiune nu are voie să se strâmbe sub nicio formă. La roți de curea o mică abatere nu s-ar simți. Dar tăierea cu disc abraziv nu cred că îl va deforma, mai ales dacă faci asta cu grijă, cu dremel-ul și cu motorul învârtindu-se.
Trimis: 13 Mar 2019 01:44 Download mesaj |
Ma refeream mai mult la faptul ca daca misti axul, risti sa disloci rulmentii, statorul etc.
Iar la unele motoare, axul are umeri, fiind practic captiv intre rulmenti.
209.69 kb |
de 7223 ori |
65.08 kb |
de 7223 ori |
StarChild Membru
Trimis: 13 Mar 2019 08:37 Download mesaj |
Exista o solutie simpla
Sub L-ul ala de e prinsa contragreutatea bagate niste saibe sau bucse care sa ridice L-ul cu acei 3-5mm necesari.
