Numar total de mesaje in forum: 237819
Vand/schimb Celestreon Astromaster 130EQ-MD motorizat
Elepsy
Data inscrierii: 26 Apr 2013
Localitate: Cluj
MesajTrimis: 26 Apr 2013 12:42 Download mesaj
Titlul subiectului: Vand/schimb Celestreon Astromaster 130EQ-MD motorizat
Telescopul reflector newtonian Astromaster 130EQ-MD este un telescop motorizat, Oglinda parabolica de 130mm . Cautatorul cu led rosu este montat permanent pe tubul optic. Design optic : reflector newtonian - Distanta focala: 650mm Marire teoretica maxima: 260x Montura: ecuatoriala Trepied otel si 2 oculare: 20mm, 10mm erecting. telescopul ESTE NOU, cumparat in Ianuarie 2013, 900 RON. pentru detalii si oferte gokel_vlad@yahoo.com
English specs:
Optical Design Newtonian Reflector
Aperture (mm) 130 mm (5.12 in)
Focal Length (mm) 650 mm (26 in)
Focal Ratio 5
Eyepiece 1 (mm) 20 mm (0.79 in)
Magnification 1 33 x
Eyepiece 2 (mm) 10 mm (0.39 in)
Magnification 2 65 x
Finderscope Built-on StarPointer
Mount CG-3 Equatorial
Tripod 1.25" steel tube legs
Weight (lbs) 24 lbs (11 kg)
Highest Useful Magnification 307 x
Lowest Useful Magnification 19 x
Limiting Stellar Magnitude 13.1
Resolution (Rayleigh) 1.07 arc seconds
Resolution (Dawes) 0.89 arc seconds
Light Gathering Power (Compared to human eye) 345 x
Angular Field of View (deg) 1.5 °
Linear Field of View (@1000 yds) 79 ft (24 m)
Optical Coatings Aluminum
Optical Tube Length 24 in (610 mm)
Tube Attachment Dovetail Bar
Motor Drive Included
 Marime fisier:  35.77 kb
 Vizualizat:  de 1291 ori
