Numar total de mesaje in forum: 224654 |
aimedbook Membru
Data inscrierii: 18 Apr 2021 Mesaje: 42
Trimis: 03 Iul 2021 07:42 Download mesaj |
Salutare, cu riscul de a fi offtopic, cum sunt botezate zonele? Exista o entitate la nivel international care aloca denumirile? Am incercat sa caut pe Google dar fara succes.
URANUS7 Membru
Data inscrierii: 21 Iun 2011 Mesaje: 2697
Motto: NICIODATA NU ESTI DESTUL DE PRICEPUT, NICIODATA NU STII SUFICIENT DE MULT DAR ...INCEARCA MEREU SA TE PERFECTIONEZI CRITICANDU-TE FARA MILA! :>) Localitate: Bucuresti
Trimis: 03 Iul 2021 11:06 Download mesaj |
DA. Este NOAA (National Oceanic and Atmospheric Administration). Uite aici:
"The National Oceanic and Atmospheric Administration (NOAA) numbers active regions consecutively as they are observed on the Sun. According to David Speich at NOAA, an active region must be observed by two observatories before it is given a number (a region may be numbered before its presence is confirmed by another observatory if a flare is observed to occur in it, however). The present numbering system started on January 5, 1972, and has been consecutive since then. An example of an active region "name" is "AR5128" (AR for Active Region) or "NOAA Region 5128". Since we only see active regions when they are on the side of the Sun facing the Earth, and the Sun rotates approximately once every 27 days (the equator rotates faster than the poles), the same active region may be seen more than once (if it lasts long enough). In this case the region will be given a new number. Hence, a long-lived active region may get several numbers.
On June 14, 2002, active region number 10000 was reached. For practical, computational reasons, active region numbers continue to have only four digits. Therefore, the sequence of numbers is 9998, 9999, 0000, 0001, and so on. Active region number 10030, for example, is AR0030. This region will often simply be referred to as region number 30, with 10030 implied."
Citesti mai mult de aici: https://hesperia.gsfc.nasa.gov/sftheory/questions.htm#AR_numbers
_________________ Gabriel |
Data inscrierii: 02 Aug 2008 Mesaje: 9481
Trimis: 03 Iul 2021 17:08 Download mesaj |
Azi a avut loc o erupție M2.7, cea mai mare din acest ciclu. Una M1.1 a avut loc în aprilie. Activitatea crește ușor, ușor. Apar regiuni active din ce în ce mai complexe și mai întinse.
URANUS7 Membru
Trimis: 03 Iul 2021 20:20 Download mesaj |
O alta imagine a regiunii AR12835, care prezintă acum o structura complexa, fascinanta prin diversitatea formelor.
Click pe imagine pentru detalii.
Descriere: |
Marime fisier: |
375.38 kb |
Vizualizat: |
de 3512 ori |
Trimis: 04 Iul 2021 08:57 Download mesaj |
Deja trebuie să rectific: ieri la ora 14.18 a avut loc o erupție și mai mare, X1.5! Păcat că nu am înregistrat nimic pe radio.
Erupția a cauzat un "blackout" pe unde scurte semnalat de mai mulți radioamatori. Asta înseamnă că a produs o anomalie serioasă în ionosferă, care de obicei asigură propagarea semnalelor radio terestre la mare distanță.
[url]
https://www.swpc.noaa.gov/products/goes-x-ray-flux[/url]
iulian90 Membru
Data inscrierii: 13 Sep 2016 Mesaje: 2400
Trimis: 04 Iul 2021 15:32 Download mesaj |
Eruptiile se pare ca au legatura cu o noua zona activa aparuta in partea nord-vestica extrema a discului solar, chiar pe limb, care a fost denumita AR 12838 ieri. In zona sunt vizibile niste facule si filamente mai deschise decat fundalul discului, dar am zarit si o mica pata solara foarte aproape de limb ,pe imaginea furnizata de SolarMonitor din data de 2 iulie.
https://solarmonitor.org/full_disk.php?dat...mp;region=
Azi am prins vreme buna si am facut capturi si observatii la Soare.
Am observat ca regiunea AR 12835 inca se tine bine, desi aria s-a mai micsorat, numarul de pete a crescut la 31, regiunea AR 12836 in schimb a disparut, regiunea AR 12837 abia se mai zareste, avand niste pete mici si pori si a mai aparut o noua regiune in partea nord-estica a discului solar, dar care nu are nume.
Am facut doua capturi de 6000 cadre la regiunea AR 12835 , cu camera NexImage, prin reflectorul de 114/900mm, la o focala efectiva mai mare de 2700mm, cu barlow-ul 3x, la care i-am pus o prelungire ca sa-i maresc magnifcatia la mai mult de 3x, pentru a scoate detalii mai fine, si o serie de 100 poze la intreg discul solar cu camera foto Canon 450D ,tot prin reflectorul de 114mm, din care am ales 75 cadre mai bune.
Descriere: |
Discul solar - 4 iulie 2021, ora 11:35 TLR. Captura: Canon 450D, reflector 114/900mm cu filtru solar. 75 cadre. |
Marime fisier: |
1.01 MB |
Vizualizat: |
de 3470 ori |
Descriere: |
Regiuna activa AR 12835. 4 iulie 2021, ora 11. Captura: NexImage 93712 @ 604x480p, 10fps, reflector 114/900mm cu filtru solar , barlow 3x modificat. |
Marime fisier: |
875.02 kb |
Vizualizat: |
de 3470 ori |
_________________ Reflector Gigant 245/1286mm
Reflector Seben 150/1400mm
Reflector Optus 76/700mm
Luneta 80/900mm
Binoclu Bresser Superfocus 10x50 |
Teo B01 Membru
Data inscrierii: 26 Sep 2019 Mesaje: 478
Trimis: 06 Iul 2021 22:10 Download mesaj |
Zona activa 12835/6 la sfarsitul periplului pe fata vizibila
Descriere: |
Marime fisier: |
69 kb |
Vizualizat: |
de 3425 ori |
URANUS7 Membru
Trimis: 08 Iul 2021 01:04 Download mesaj |
Azi, ce a mai rămas vizibil, in lumina albă, din AR12839.
In frecventa H-alfa însă, regiunea arată a fi destul de activă, cu structuri deosebit de interesante.
Descriere: |
Marime fisier: |
403.93 kb |
Vizualizat: |
de 3402 ori |
URANUS7 Membru
Trimis: 08 Iul 2021 22:38 Download mesaj |
Discul solar de azi, in care apar AR12839 (văzut ca un punct) si AR12837 căruia ii putem vedea doar plaja (partea dreapta a discului, aproape de limb). Captura in condiții de ceață. Dați click pe imagine.
Descriere: |
Marime fisier: |
169.74 kb |
Vizualizat: |
de 3370 ori |
URANUS7 Membru
Trimis: 09 Iul 2021 00:52 Download mesaj |
Azi, un close-up la rămășitele lui AR12839.
Descriere: |
Marime fisier: |
519.57 kb |
Vizualizat: |
de 3357 ori |
URANUS7 Membru
Trimis: 10 Iul 2021 22:51 Download mesaj |
AR12841 de astăzi. Captura prin ceață.
Descriere: |
Marime fisier: |
314.81 kb |
Vizualizat: |
de 3322 ori |
Trimis: 11 Iul 2021 08:21 Download mesaj |
Azi avem încă 2 regiuni, 41 și 42 la limbul estic iar cea din urmă promite mai mult, având o pată mai mare. Regiunea 40 deja trecută de limbul vestic a mai dat alaltăieri 3 erupții clasa C6, C7 și C4.7.
Având în vedere desfășurarea de forțe actuală aș înclina să cred că cei care au prognozat un ciclu 25 mai mare decât oricare din ultima sută de ani au dreptate. Vom vedea!
URANUS7 Membru
Trimis: 15 Iul 2021 00:08 Download mesaj |
AR12842 de astăzi, capturat prin ușoară ceața.
Este o regiune activa de clasa alfa Hale, având un singur spot.
Mărimea ei pare a fi in scădere.
Descriere: |
Marime fisier: |
295.2 kb |
Vizualizat: |
de 3277 ori |
URANUS7 Membru
Trimis: 15 Iul 2021 20:21 Download mesaj |
AR12842 de astăzi. Seeing 4/5, transparenta 8/10.
Descriere: |
Marime fisier: |
102.68 kb |
Vizualizat: |
de 3255 ori |
URANUS7 Membru
Trimis: 18 Iul 2021 21:15 Download mesaj |
AR12842 de astăzi, care are un reviriment, crescându-si atât suprafața cat si numărul de pete, acum 5 fata de ieri când avea doar una. Impresionant este ca deja s-au structurat poduri luminoase complexe peste unele dintre ele.
Imagine rotita cu -90 grade.
Descriere: |
Marime fisier: |
481.18 kb |
Vizualizat: |
de 3205 ori |
Ultima modificare efectuata de catre URANUS7 la 19 Iul 2021 10:21, modificat de 1 data in total |
