Numar total de mesaje in forum: 242336
Filtru solar nou orig. Celestron pt apertura 6" (150mm)
Peavy
Data inscrierii: 25 Apr 2010
MesajTrimis: 03 Aug 2014 13:56 Download mesaj
Titlul subiectului: Filtru solar nou orig. Celestron pt apertura 6" (150mm)
Filtrul este nou in cutie, are folie Baader Astro Solar si se potriveste pe telescoape Schmidt-Cassegrain cu apertura de 6" (150mm). Este de foarte buna calitate si se gaseste rar de cumparat chiar si in strainatate.
Pret 200 de lei. PM sau tel 0722995931
Description
Celestron Solar Filters are made with Baader Astro Solar™ Safety Film. Far superior than any existing glass, Mylar or polymer filters, they lead to brighter, sharper, and higher contrast images.
Enter the new millennium with the finest solar filters available. Astro Solar™ Safety Film is clear and homogenous and attains the optical performance of high quality plane-parallel glass filters—it is diffraction limited! Double-sided metal coatings have uniform density and good color balance across the entire field ensuring razor sharp images from edge to edge.
The Sun appears in its “real ”color —neutral white, not blue or orange, and the sky adjacent to the solar limb is jet black.
You can see detail in sunspots, bright faculae near the limb and the mottled areas known as granules with these filters. The Sun offers constant changes and will keep your observing interesting and fun. Even small aperture telescopes can enjoy features of the Sun.
The Astro Solar™ film is completely safe and durable (won‘t break like glass if dropped). Its rating is ND-5 which means that the film transmits 1/100,000 of visible light (.001%) while reflecting (blocking) 99.999%of unwanted light. The film absorbs all ultraviolet rays while coating reflects infrared light rendering both absolutely harmless. For added assurance, Baader Astro Solar™ film has been declared safe for direct solar viewing by the German National Bureau of Standards for eye safety.
 Marime fisier:  516.14 kb
 Vizualizat:  de 1624 ori
 Marime fisier:  649.75 kb
 Marime fisier:  727.1 kb
 Marime fisier:  569.35 kb
 Marime fisier:  480.71 kb
Celestron NexStar 6SE
Peavy
MesajTrimis: 22 Aug 2014 17:13 Download mesaj
valabil
Peavy
MesajTrimis: 26 Aug 2014 11:16 Download mesaj
Vandut. Se poate inchide, multumesc.
