Numar total de mesaje in forum: 234025
ATYK CCD
gabi
Data inscrierii: 13 Mai 2010
MesajTrimis: 22 Sep 2010 08:26 Download mesaj
Brosura filtre Baader, partial.
The set consists of following colors (Note the
spectral trace for each color!)
 Dark blue (435 nm) # 2458302
 Bright blue (470 nm) # 2458303
 Green (500 nm) # 2458304
 Yellow (495 nm) # 2458301
 Orange (570 nm) # 2458306
 Red (6 1 0 nm) # 2458307
Transmission efficiencies for the three longpassfilters
(Yellow, orange and red) peaks at 98 %,
while the efficiency for the three bandpass-filters
peaks at almost 70 percent – unheard of for a
simple colored glass-filter!
All filters have standard 11⁄4“ eyepiece filter
threads, tested and optimized to fit allmost all
eyepieces on the market. Each filtercell has a male
as well as a female thread to allow stacking for
narrower passbands or to combine with our UV/IRCut-
filter. The combination of the red
RG 610 (# 2458307) and IR-Cut-filter (# 2459207)
for instance results in an extremely narrow H-α
passband-filter – at an incredibly cheap price.
Gabi.
Emil
Data inscrierii: 30 Aug 2007
Localitate: Fuerstenfeld
MesajTrimis: 22 Sep 2010 08:56 Download mesaj
doua filtre implica uneori - chiar destul de des - reflexii intre suprafetele lor deci artefacte in imagine, eu personal as evita stackarea lor.
h-alfa-ul de 35 nm nu este asa scump si cu un astfel de filtru am inceput eu.
Vlad are o imagine postata cu un astfel de filtru.
Iar declaratia de la baader ca ar fi extrem de ingust nu o pot verifica era bine daca dadeau valoarea ferestrei de transmisie atunci mi-ar fi fost mai usor sa fac o apreciere...
Emil
MesajTrimis: 22 Sep 2010 13:54 Download mesaj
Cam mult marketing.
Filtrul rosu: http://www.baader-planetarium.de/sektion/s..._gross.jpg
Filtrul UV-IR: http://www.alpineastro.com/filters/images/UV_IR_Cut_Curve.gif
Combinatia intre cele doua se poate vedea in ultimul grafic: http://www.alpineastro.com/filters/images/uv_ir_data_Sheet.pdf
Ochiometric iti da un bandpass de 100 nm (600-700 nm). In plus, filtrul UV-IR este dicroic. Adica este oglinda pentru ce nu trece si iti va genera reflexii multiple "frumoase" in combinatie cu un alt filtru. Mai ales la un raport focal mic.
Emil
MesajTrimis: 23 Sep 2010 01:12 Download mesaj
"extremely narrow H-α"
buna treaba he he he reclama aiurea, am trecut de pe 35 nm ca era prea larga fereastra de transmisie pe 6 nm de la Astrodon si acu pot spune ca "I like to move it move it" scuzati dar nu m-am putut abtine Very Happy
Pai eu cu 6 nm sunt "insane narrow" sau cum? Aia sa nu ne legam de cele de 3 nm.
2 filtre stackate e aiurea din toate punctele de vedere.
Emil
gabi
MesajTrimis: 25 Sep 2010 18:20 Download mesaj
Am mai cautat pe internet si am gasit trei modele de camere ATIK.
314L+ Sony ICX 285AL Pixel 6,45 uM X 6,45 uM. -1282 EURO
320E Sony ICX 274 Pixel 4,40 uM X 4,40 uM. - 989 EURO
314E Sony ICX 205AL Pixel 4,65 uM x 4,65 uM. - 865 EURO
Daca aleg 314L+ nu imi mai permit si alte accesorii [roata filtre, LRGB filtre,etc].
Daca ati putea alege intre aceste variante ce ati face ? sau mai direct ce imi recomandati din experienta voastra .
Multumesc .
Gabi
Emil
MesajTrimis: 25 Sep 2010 19:01 Download mesaj
pixelul mic e bun pentru focale mici.
nu stiu daca ai specificat optica care o folosesti.
pana la roata de filtre mai ai timp eu zic la inceput sa iei doar camera dupa ce ai ajuns sa o cunosti bine si sa scoti imagini bune sa treci la o roata de filtre.
pentru roata de filtre iti trebuie pe de o parte rabdare si mai ales timp deoarece trebuie sa expui fiecare canal in parte...
Emil
Vlad
Data inscrierii: 10 Sep 2008
Localitate: Alicante
MesajTrimis: 25 Sep 2010 19:06 Download mesaj
Cea mai buna dintre cele trei este Atik 314L+
Eu zic ca merita asta chiar daca nu-ti permiti altele deocamdata. Mai bine iei cel mai bun posibil, iar restul cand se poate
gabi
MesajTrimis: 25 Sep 2010 19:13 Download mesaj
Salut, Emil si multumesc,
Am focala de 625 mm/f7,7 900mm/f7,5 900mm/f4,5 cel mai bine ar merge ATIK 314L+ 6,45uM pixel { asa cred.}
La Teleskop-Express am gasit cel mai bun pret.
Gabi.
Vlad
MesajTrimis: 25 Sep 2010 19:18 Download mesaj
se vinde una la mana a doua , cu 9 luni vechime, pe astromart, la 900 euro.. Acolo trebuie sa te inregistrezi si sa platesti ca sa-ti faci cont, insa acelasi tip (din grecia!) o are de vanzare si pe www.astrobuysell.com/uk unde poti sa-i gasesti emailul gratis. Pe aceasta pagina din urma pretul este putin mai scump, probabil ca nu a actualizat.
Tot el vinde si o roata de filtre atik manuala.
gabi
MesajTrimis: 25 Sep 2010 19:26 Download mesaj
Da VLAD am vazut si eu anunturile pe Astobuysell dar pot cumpara ATIK 314L+ noua cu 1100 euro transport inclus. Detalii in PM .
Gabi.
Pagina 2 din 2
