Numar total de mesaje in forum: 242127
Oculare 2" Celestron Ultima LX 22mm si 32mm
Peavy
Data inscrierii: 25 Apr 2010
MesajTrimis: 05 Iul 2014 20:28 Download mesaj
Titlul subiectului: Oculare 2" Celestron Ultima LX 22mm si 32mm
Ocularele au fost pastrate in cutie si ingrijite si sunt in stare foarte buna, fara urme de folosinta. Calitatea pe care o ofera la observatii vizuale este excelenta, eu le consider peste Baader Hyperion. Camp vizual larg de 70 de grade, eye relief confortabil.
500 de lei bucata. PM sau tel 0722995931
In magazin costa 765 de lei.
http://www.skywatcher.ro/Cel/oc_ultimalx.htm
 Marime fisier:  738.18 kb
 Vizualizat:  de 4600 ori
 Marime fisier:  697.88 kb
 Marime fisier:  724.66 kb
 Marime fisier:  673.64 kb
 Marime fisier:  612.54 kb
 Marime fisier:  730.33 kb
 Marime fisier:  840.95 kb
Celestron NexStar 6SE
Peavy
MesajTrimis: 12 Iul 2014 12:35 Download mesaj
Mai multe caracteristici:
Celestron's Ultima eyepieces were voted best in their class by Sky & Telescope magazine. These eyepieces use a 5-element optical design and feature long eye relief and wide fields of view. Each of the air-to-glass surface on the entire Ultima range are fully multicoated to enhance contrast levels. The Ultima series of Celestron eyepieces were computer designed to keep aberrations to an absolute minimum. They virtually eliminate spherical, colour, field curvature, coma, astigmatism, distortion and spherical distortion of the exit pupil. The inside surfaces and edges of the lenses are blackened to keep out reflected light. Outside surfaces are flat black and include rubber grips for secure handling. Rubber eyecups are also included both for comfortable use and to keep out extraneous light.
Roll guard - Ergonomic contours prevent eyepiece from rolling off flat surfaces
28mm clear aperture surface lens - For comfortable viewing
70 degree Field - Wide FOV for high and low magnifications
Extendable twist-up eyecups - Good for eyeglass wearers
Parfocal eyepiece - Little or no focusing is needed when changing from low to high power.
Threaded barrels - Accept 2" Celestron thread-in filters.
Shock resistant rubber covering - Scratch and dent resistant
No slip grip - Designed for secure handling even in moist conditions
ANGULAR FIELD OF VIEW: 70 °
EYE RELIEF: 16 mm
OPTICAL COATINGS: Fully Multi Coated
OPTICAL DESIGN: 6-elements
PARFOCAL: Yes
 Marime fisier:  842.08 kb
 Vizualizat:  de 4478 ori
 Marime fisier:  817.57 kb
Peavy
MesajTrimis: 18 Iul 2014 17:15 Download mesaj
Valabil
Peavy
MesajTrimis: 28 Iul 2014 21:42 Download mesaj
Daca cineva doreste sa cumpere ambele oculare ofer gratuit aceasta geanta pentru accesorii cu spuma ce poate fi modificata in funtie de necesitati.
 Marime fisier:  791.2 kb
 Vizualizat:  de 4299 ori
 Marime fisier:  688.56 kb
Peavy
MesajTrimis: 09 Aug 2014 19:27 Download mesaj
valabil
Peavy
MesajTrimis: 26 Aug 2014 11:53 Download mesaj
valabil
Peavy
MesajTrimis: 03 Sep 2014 15:40 Download mesaj
valabil
Peavy
MesajTrimis: 18 Sep 2014 14:17 Download mesaj
disponibile in continuare
Peavy
MesajTrimis: 09 Oct 2014 14:58 Download mesaj
valabil
Peavy
MesajTrimis: 27 Oct 2014 11:42 Download mesaj
anunt valabil
katran
Data inscrierii: 21 Iul 2014
MesajTrimis: 03 Noi 2014 18:46 Download mesaj
Le cumpar ... un nr. de tel sa vorbim ?
cheers.
Peavy
MesajTrimis: 03 Noi 2014 19:01 Download mesaj
Nr. meu e 0722 995 931
Peavy
MesajTrimis: 13 Noi 2014 18:56 Download mesaj
Ocularele s-au dat. Se poate inchide, multumesc.
