Publicatii
Numar total de mesaje in forum: 188502
Numar de utilizatori inregistrati: 2468
Cel mai nou utilizator inregistrat: Marcel Epure
ECLIPSA DE SOARE 04 ian 2011
Du-te la pagina Anterioara  1, 2, 3, 4, 5, 6, 7, 8  Urmatoare
Eclipse
Dan Vasiliu
Data inscrierii: 29 Iun 2009
Motto: SI SEDES NON IS
MesajTrimis: 04 Ian 2011 19:23 Download mesaj
Sistemul folosit la fotografii a fost:
Refractor 120, f/8.33 -> filtru ND4 -> prisma Herschel -> filtru Baader solar continuum -> DSLR (atasat cu asta: http://magazin.telescop-expert.ro/adaptor-de-la-317508-la-t2.html )
CER SENIN !
MesajTrimis: 04 Ian 2011 19:35 Download mesaj
Rolling Eyes esti sigur ca asta a fost ordinea???
Ce fel de filtru nd4?
Alex Gaina
Data inscrierii: 02 Iul 2004
Localitate: Chisinau
MesajTrimis: 04 Ian 2011 19:47 Download mesaj
Titlul subiectului: THE SUN's ECLIPSE FROM 4 JANUARY 2011 (English and Romanian)
ENGLISH
I will not atach photographs now. I am not sure that they are good all. Part of them should be good, in spite of they are made by FED (1979 production). They should be developed.
I begun observations at LT8:30 (UT 6:30). I have registered 1-st contact at LT 9:17(UT 7:17) in a point placed in the 1-st quadrant (West and upper part of the disk) at an angle of 45 degrees at the Sun's disk. The Maximum of the eclipse took place at LT10:48(UT12:4Cool. At the maximal phase about 75% of the Sun's disk was covered by the Moon. The last contact took place at LT12:13:30 (UT9:13:30). The eclipse finished in a point placed simmetrically, relatively the vertical line, to the point of 1-st contact. The right and lower part of the Sun's disk was every time bright. The sky was serene. No clouds, no wind. t=-2C without changes during the eclipse. The maximum height of the Sun was about 20Deg. The Azimuth of the Sun was about 160Deg;
I would like to compare my observations with data from:
http://eclipse.gsfc.nasa.gov/OH/OHtables/OH2011-Tab01.pdf
At these NASA eclipses site the following data for Chisinau are given:
C1= 7:15
M=8:43
C4= 12:16
H= 18 Deg.
A= 159Deg.
The errors are minimal (2 min for the 1-st contact, 5 min for the maximum of the eclipse, 3 min. for the end of the eclipse). I can explain the error in the beggining and the end by late of the registering of the first contact and shortennge of the observations during the last stages).
I have used just hand's clocks, a CD for the covering of the Sun's surface and fingers of my hand. The Photos I hope to post later.
ROMANIAN (Pentru cei....)
Nu voi atasa acuma imagini. Nu sunt sigur, că au reușit toate. Le-am făcut cu FED-ul. Pe parcurs, sper sa le atasez.
Am inceput să observ la orele LT8:30. După mine 1-mul contact a avut loc la orele LT9:17. Punctul de contact se situa in primul quadrant aproximativ la 45 grade. Eclipsa maxima a avut loc la LT10:48. Faza maxima a fost de aproximativ 75%. Ultimul contact la LT 12:13:30, in punctul simetric fata de primul in raport cu verticala pe discul soarelui. Momente mai importante:
Leaganul, adica partea mai luminata a discului a fost intotdeauna cu cornul stang (rasaritean) superior celui drept (apusean). Inaltimea Soarelui 20Deg, A=160 Deg,
Am folosit pentru observatii cele mai necajite mijloace: degetele de la mana, un CD pentru protectie si observarea suprafetei soarelui, un ceas de 18 lei (1,5$SUA)
cmatei
Data inscrierii: 09 Sep 2009
MesajTrimis: 04 Ian 2011 20:41 Download mesaj
Prin luneta am avut doar cateva ferestre in care soarele putea fi observat prin filtru. De fotografie nici vorba.
Ca prin ceata
 Marime fisier:  298.94 kb
 Vizualizat:  de 4905 ori
Dan Vasiliu
MesajTrimis: 04 Ian 2011 20:46 Download mesaj
Filtrul este atasabil la oculare de 1,25". Stiu ca normal filtrul ND trebuia sa fie intre prisma Hershel si filtrul solar continuum dar am constatat in timp ca merge si asa. Pana la proba contrarie ... Daca face poc inseamna ca am gandit prost. Laughing
In fapt, daca-l puneam la locul lui, nu mai focalizam corect pe senzorul DSLR-ului. Trebuie sa schimb focalizatorul de la luneta cu unul mai putin inalt. Musai! Wink
PS: Acum nu mai stiu daca este ND4 sau ND3. Ma uit cand ajung acasa.
CER SENIN !
Dan Vasiliu
MesajTrimis: 04 Ian 2011 20:57 Download mesaj
Am gasit! Filtrul ND3 de aici:
http://www.skywatcher.ro/Baader/filtre_neutre.htm
CER SENIN !
recab
Data inscrierii: 07 Noi 2010
Motto: "Eppur si muove"
Localitate: italia
MesajTrimis: 04 Ian 2011 21:23 Download mesaj
Eclipsa vazuta printre nori la care am folosit un filtru improvizat(tipla dela buchetul de flori legata cu un elastic) calitatea imaginilor nu este forte buna dar cel putin m-a protejat Very Happy
 Marime fisier:  65.91 kb
 Vizualizat:  de 4866 ori
 Marime fisier:  71.6 kb
 Marime fisier:  128.62 kb
 Marime fisier:  104.34 kb
Ziel orbiter 35,114/910, f/8 newton,oculare Ts WA 20mm,Geoptik Planetary HR 8mm,barlow 2x TS
MesajTrimis: 04 Ian 2011 22:45 Download mesaj
Dan Vasiliu a scris:
Am gasit! Filtrul ND3 ...
De obicei prisma Herschel este cea care se monteaza prima dupa obiectiv pe traseul optic.
Ea este aceea care evacueaza din sistem surplusul energetic (95-96%).
Dupa prisma se monteaza filtrul ND3 si filtrul suplimentar de contrast sau banda ingusta.
In varianta aleasa de tine cea mai mare parte din energie se disipa in filtrul ND, nu se mai evacueaza din sistem si exista riscul ca intr-o buna zi acesta sa faca "poc"!
Tot in aceasta varianta rolul prismei Herschel se reduce in principal la functia unei diagonale obisnuite.
Catalin Paduraru
Data inscrierii: 08 Mai 2006
MesajTrimis: 04 Ian 2011 23:15 Download mesaj
Salut, se pare ca o poza face furori J Adica este Editor’s Choise la Sky and Telescope Magazine. Sa vedem daca mai apara si prin alte parti.
Link: http://www.skyandtelescope.com/community/gallery
Numai bine!
Dan Vasiliu
MesajTrimis: 04 Ian 2011 23:47 Download mesaj
@Zoth ai perfecta dreptate. Din pacate "setup-ul meu pentru observatii solare" se afla in alta locatie. Eclipsa am urmarit-o de acasa cu ce am avut la indemana. Daca ma va ajuta timpul o sa reusesc sa finalizez observatorul solar - unde toate vor fi la locul lor.
Am specificat, refractorul pe care l-am folosit nu are suficient in-focus pentru poze. Daca montam filtrele corect nu mai puteam focaliza. A fost un compromis. Refractorul l-am achizitionat de curand si nu m-am invatat cu el.
Trebuia sa fac ceva sa nu ratez momentul. Wink
@Catalin, poza este intradevar super ! Felicitari!
CER SENIN !
achy1978
Data inscrierii: 24 Dec 2007
Localitate: Targu Jiu
MesajTrimis: 05 Ian 2011 01:23 Download mesaj
Dupa o deplasare de 100 Km dincolo de munti, deplasare facuta impreuna cu Marcel Jinca, am reusit sa gasim un ochi (de cca 30-35 Km diametru) de cer senin. Am putut observa astfel eclipsa in conditii bune (au mai existat cativa nori sporadici si ceata). Atasez cateva imagini la anumite intervale de timp.
Locatia este undeva intre Petrosani si Hateg
Cer senin,
Marian
 Marime fisier:  316.25 kb
 Vizualizat:  de 4734 ori
 Marime fisier:  272 kb
 Marime fisier:  257.51 kb
 Marime fisier:  269.46 kb
 Marime fisier:  275.72 kb
 Marime fisier:  295.56 kb
 Marime fisier:  330.94 kb
 Marime fisier:  337.44 kb
 Marime fisier:  334.26 kb
Marian Lucian ACHIM
SRCSTV - www.srcstv.ro
SARM - www.sarm.ro
Alex B.
Data inscrierii: 10 Mai 2009
MesajTrimis: 05 Ian 2011 01:38 Download mesaj
Câteva imagini făcute la trecerea ceții peste zona mea de București. Aparatul este un Pentax K-x cu zoom-ul din dotare. Le-am făcut când nu se mai vedea nimic pe ecranul de proiecție din spatele lunetei. Smile A se vedea de jos în sus (sucită aplicație...). Laughing
Moment 07:59 UT
 Marime fisier:  61.36 kb
 Vizualizat:  de 4724 ori
Mmoment 08:00 UT
 Marime fisier:  62.07 kb
Moment 08:04 UT
 Marime fisier:  59.51 kb
Moment 08:25 UT (aproape de maxim)
 Marime fisier:  54.25 kb
marcel jinca
Data inscrierii: 16 Apr 2009
MesajTrimis: 05 Ian 2011 09:14 Download mesaj
Un .gif realizat din fotografiile lui achy1978 - Marian Achim.
 Marime fisier:  928.92 kb
 Vizualizat:  de 4690 ori
recab
Localitate: italia
MesajTrimis: 05 Ian 2011 09:23 Download mesaj
Foarte fain gif-ul, si toate celelalte eclipse Very Happy
Kissulescu
Data inscrierii: 29 Oct 2008
MesajTrimis: 05 Ian 2011 10:35 Download mesaj
Titlul subiectului: re
Am facut si eu cateva imagini la eclipsa.
 Marime fisier:  28.96 kb
 Vizualizat:  de 4642 ori
 Marime fisier:  20.25 kb
 Marime fisier:  17.5 kb
 Marime fisier:  26.54 kb
Skywatcher 254/1200mm
Canon EOS 350D
www.refuzake.info
Creaza un subiect nou   Raspunde la subiect   Eclipse Du-te la pagina Anterioara  1, 2, 3, 4, 5, 6, 7, 8  Urmatoare
Pagina 5 din 8
