Publicatii
Numar total de mesaje in forum: 179996
Numar de utilizatori inregistrati: 2471
Cel mai nou utilizator inregistrat: telescope08
Vand barlow GSO 2.5X 1.25"
Alex Alexandru
Data inscrierii: 19 Sep 2018
MesajTrimis: 07 Dec 2018 13:07 Download mesaj
Titlul subiectului: Vand barlow GSO 2.5X 1.25"
Vand barlow ca nou (iunie 2017 astroshop) GSO, fully multi coated.
Il vand pentru ca am trecut pe 2". Pret: 150 RON.
Specificatii si reviewuri (4.8 din 36 reviewuri) aici:
https://agenaastro.com/gso-2-5x-apo-barlow-lens.html
Manufacturer GSO
Size Format 1.25 inch
Magnification Factor 2.5x
Number of Lens Elements
Lens Coatings Fully multicoated
Total Length 2.95 inches / 75 mm
Length of Nosepiece 1.18 inches / 30 mm
Outside Length of Upper Body 1.8 inches / 45.7 mm
Insertion Depth 1.57 inches / 40 mm
Max Diameter Excluding Thumbscrew 1.92 inches / 48.8 mm
Clear Aperture 0.88 inches / 22.4 mm
Weight 3.5 oz / 99 g
Barlow Lens Cell Removable No
Filter Threads at Bottom of Barlow Cell No
Filter Threads Between Barlow Cell and Tube N/A
Barrel Type Smooth-sided
Compatible Agena Bolt Case (with Screw Removed) 42x80
Compatible Bolt Case (with Screw Attached) 52x80
Number of Thumbscews 1
Thumbscrew Thread Specification M4x0.7
End Caps (Subject to change without notice) 2
Compression Band/Ring in Eyepiece Holder Yes
Country of Manufacture Taiwan
 Marime fisier:  811.8 kb
 Vizualizat:  de 336 ori
 Marime fisier:  935.55 kb
V. Istvan
Data inscrierii: 11 Ian 2015
Localitate: Targu Mures
MesajTrimis: 07 Dec 2018 16:32 Download mesaj
E chiar bun... Am acest tip de Barlow și sunt mulțumit de el... Nu introduce aberații sesizabile de nici un fel...
Telescop Newton 150/750 cu tubul de constructie proprie
Binoclu Bushnell 7x50
Alex Alexandru
MesajTrimis: 07 Dec 2018 16:55 Download mesaj
Titlul subiectului: multumesc
Multumesc pentru apreciere... eu pot spune ca nu sunt expert si nu sesizez cu usurinta aberatii cromatice, insa ce pot spune cu certitudine este ca este si mai luminos (nu intuneca imaginea la fel de tare) si evident mareste mai bine decat 2 X -ul de la Celestron (cel cu care vine kitul Celestron AstroMaster II).
Alex Alexandru
MesajTrimis: 08 Dec 2018 10:21 Download mesaj
Titlul subiectului: Update
Rezervat
Alex Alexandru
MesajTrimis: 08 Dec 2018 12:52 Download mesaj
Vandut
