Numar total de mesaje in forum: 240740
PHD ver 2
Soft pentru astronomie
iosif
Data inscrierii: 17 Oct 2012
Localitate: Sandra Timis
MesajTrimis: 06 Mar 2017 15:08 Download mesaj
Titlul subiectului: PHD2 v2.6.3 12 February 2017
- Reliablility improvements and SDK updates for various cameras: ZWO, SX, Altair, SBIG, and WDM webcams
- Comet tool fixes
- Display improvements for small screens and high-DPI screens
- New star-cross test tool
- Stats window now displays image size and guider FOV
- AO enhancements: display RA and Dec directions on the AO graph, automatically increase bump step size when dither settling
- Allow Dec dither when Dec guide mode is north or south by temporarily switching to bi-directional dec guiding until dither settles
- Star mass change detection now works when exposure is Auto
- OSX: disable AppNap on OSX versions >= 10.9
- Server API: various new functions added
- Various logging and diagnostic improvements
- Updated translations
- Updated help documentation
Download.
http://openphdguiding.org/phd2-2.6.3-installer.exe
_______________________________________________
iosif
MesajTrimis: 21 Mar 2017 19:04 Download mesaj
Titlul subiectului: PHD2 v2.6.3dev1
PHD2 v2.6.3dev1 20 March 2017
- New image logging options based on trigger events, like star lost or large error offset
- Option to determine star saturation based on ADU value rather than star profile
- Improved detection of low-snr stars by more accurate background calculation
- Improved star mass change detection
- New option to reject stars below a minimum size (HFD)
- AO: fix bug with AO bump continuing after server received Pause command
- Add more info to fits headers when saving images
- Event server: add get_settling method
Download
http://openphdguiding.org/phd2-2.6.3dev1-installer.exe
_________________________________________________
MesajTrimis: 27 Mar 2017 01:46 Download mesaj
Am instalat PHD, ultima versiune si totul pare ok doar ca steaua desi se misca nu mi-o aduce in centru, Ce poate fi gresit?
Multumesc.
 Marime fisier:  312.88 kb
 Vizualizat:  de 14727 ori
iosif
MesajTrimis: 27 Mar 2017 01:51 Download mesaj
Salut.
Pune la 1,5 s-au la 2 sec nu la 0.5.
Mai da detalii la setari. Cu ce ghidezi, camera.
Si cred ca ai facut o calibrare la inceput.
Salut.
 Marime fisier:  328.69 kb
 Vizualizat:  de 14724 ori
MesajTrimis: 27 Mar 2017 08:33 Download mesaj
Focala 600mm, e o camera noname color 2500x1900 px setata sa capteze la 800x600px (resize, nu crop). Am senzatia ca nu se prinde de magnitudinea deplasarii stelei. N-am facut o calibrare...sa vad ce pp. asta.
MesajTrimis: 28 Mar 2017 12:30 Download mesaj
iosif a scris:
.. camera...calibrare la inceput...
Punct ochit punct lovit, inca nu pot confirma practic, dar se pare ca setasem un pixelsize de 10 ori mai mic, iar calibrarea era facuta initial pe un bec (era nor Smile ), si intre timp s-a mai miscat/rotit camera.
Refac testele in zilele urmatoare.
Multumesc.
MesajTrimis: 29 Mar 2017 01:02 Download mesaj
L-am calibrat aproximativ, acum incearca sa tina steaua in centru o perioada dar nu urmareste prea fidel.
 Marime fisier:  219.49 kb
 Vizualizat:  de 14655 ori
 Marime fisier:  234.26 kb
 Vizualizat:  de 14647 ori
iosif
MesajTrimis: 29 Mar 2017 18:39 Download mesaj
Titlul subiectului: PHD2 v2.6.3dev2
PHD2 v2.6.3dev2 28 March 2017
- New Predictive PEC guide algorithm!
- Mac: fix problem with SX camera not being found
- Camera gain setting should not allow value 0
- Comet tracking: adjust RA shift rate for scope declination
Download
http://openphdguiding.org/phd2-2.6.3dev2-installer.exe
iosif
MesajTrimis: 11 Apr 2017 00:17 Download mesaj
Titlul subiectului: PHD2 v2.6.3dev3
PHD2 v2.6.3dev3 10 April 2017
- More strict protection against windows being placed off-screen after screen resolution changes
- Predictive PEC settings UI improvements in Advanced Dialog
- Predictive PEC key settings added to Grpah window
- additional information saved to FITS headers when saving an image
- QHY cameras: we now use an up-to-date QHY camera SDK for native support of QHY cameras on Windows, Mac, and Linux
Download.
http://openphdguiding.org/phd2-2.6.3dev3-installer.exe
_______________________________________________________
MesajTrimis: 11 Apr 2017 00:35 Download mesaj
Are vreo limita in amplitudinea maxima a deviatiei stelei ce poate fi corectata?
iosif
MesajTrimis: 29 Apr 2017 14:55 Download mesaj
Titlul subiectului: PHD2 v2.6.3dev4
PHD2 v2.6.3dev4 29 April 2017
- Fix RA/Dec overlay when AO is in use
- Server API additions to get calibration information and send guide pulses to scope
- Improve Guiding Assistant text layout for some translations
- Additional debug log output for the PPEC guide algorithm
- A new Portuguese (Brazilian) translation
- Default Gain for QHY cameras is now 40
- Update QHY camera SDK to V7.4.16.4
- Update Altair SDK to latest 1.1.4 version to support new camera models
- Fix crash when stats window is updated and Camera = None
- Update ZWO Linux/Mac SDK to V0.6.0328
- Don't allow Predictive PEC period value to be disrupted when the guiding assitant is run
- Updated French translation
Download.
http://openphdguiding.org/phd2-2.6.3dev4-installer.exe
iosif
MesajTrimis: 01 Iun 2017 12:14 Download mesaj
Titlul subiectului: PHD2 v2.6.3dev5
PHD2 v2.6.3dev5 31 May 2017
- Updated Portuguese translation
- Windows installer - do not run the VC++ redistributable installer
- Fix text truncation with some translations in spctrograph slit position window
- Mac: fix crash when disconnecting GPUSB
- Adjust guiding parameters automatically when camera binning is changed
- PPEC: fix problem with min-move parameter not being honored
- Make sure not to retain calibration unless auto-load calibration is selected
- Display AO correction rate in AO graph window
- Help file updates
- Guard against too-small aggressiveness or hysteresis settings being entered
- Allow custom camera exposure duration selection
Download.
http://openphdguiding.org/phd2-2.6.3dev5-installer.exe
 Marime fisier:  198.61 kb
 Vizualizat:  de 14330 ori
iosif
MesajTrimis: 14 Iun 2017 01:16 Download mesaj
Titlul subiectului: PHD2 v2.6.3dev6
PHD2 v2.6.3dev6 13 June 2017
- QHY cameras: fix incorrect guide directions when using On-camera (ST4) guiding
- Restart PHD2 automatically when language changes or when the Reset Configuration option is selected
- Help file updates
- New option to automatically check for software updates
Download.
http://openphdguiding.org/phd2-2.6.3dev6-installer.exe
iosif
MesajTrimis: 03 Sep 2017 12:09 Download mesaj
Titlul subiectului: PHD2 v2.6.3dev8
PHD2 v2.6.3dev8
2 September 2017
-Altair cameras: update to new SDK version (2017-09-01)
-Updated French translation from Cyril
-Guide log: only show gain value when PHD2 is controlling the gain
-AO: better handling of step failures: show an alert and suggest new AO travel limit setting
-AO: fix bump instability when guide star is far from lock position
-AO: make sure calibration covers full travel range
-INDI fixes
-Updated Windows INDI client libs
-Do not allow invalid hysteresis setting (100%)
-Fix problem with server sometimes not restarting when PHD2 is restarted
-Allow cam simulator to simulate async ST4 guiding
-Do not tie up main UI thread for GPxxx and INDI mounts and AO moves
-Include milliseconds in FITS header timestamps
-Help file updates
-Debug log enhancements
Download.
http://openphdguiding.org/phd2-2.6.3dev8-installer.exe
_______________________________________________________________
iosif
MesajTrimis: 26 Sep 2017 13:35 Download mesaj
Titlul subiectului: PHD2 v2.6.4
PHD2 v2.6.4 25 September 2017
- Fix bugs in calibration review and calibration sanity check when Dec guiding is disabled
- Update to latest ZWO ASI SDK
Download.
http://openphdguiding.org/phd2-2.6.4-installer.exe
Creaza un subiect nou   Raspunde la subiect   Soft pentru astronomie Du-te la pagina Anterioara  1, 2, 3, 4, 5, 6, 7  Urmatoare
Pagina 4 din 7
